Da-88
  • Thread starter Thread starter Lou Corio
L
Lou Corio
On my DA-88 I'm not getting any LED signal's on 1-3-5-7 and on 2-4-6-8 I'm getting static or white noise with showing a signal. This is the master machine and I have one slave DA-88. The tapes play fine and the LED's work fine on the slave unit. I disconnected input and output cables and the cable to link the two machines together and tried playing the tape on the master machine and still had the same problem. thank you Lou
Have the machine professionally cleaned unless you know how to do it yourself. If you're lucky, that's all it needs. If not, you may need a new head drum. Not worth fixing, IMHO.
