Atkron205
Member
After I moved my stuff, now my cue buss will not work. I didnt change any connections on my physical rack or change any settings in Cubase. I have a cue buss set up in control room, am using line outs 5/6 for the signal input into my headphone amp. no matter what I do I can only get the main LR mix output from 5/6. I have tried deleting the buss and adding it back. When I activate the cue sends, I can see the meter output in the control room cue, the channel sends work as far as I can turn one down and see it on the cue output meter. If I go into the UR 824 program, the only way I get signal out of 5/6 is to route the LR mix to 5/6.
