solit said:
Hello-
I'm setting up a home PC Studio running off of an Audiophile 2496.
I plan to mix on my computer.
1. What would be the best mixing software for a novice to learn and mixdown tracks. why?
2. What would you recommend as the best way to try to learn how to mix? thanks!
To answer your question...
Since you already have an interface, Pro Tools LE will not work with so it is not a cost efficient option- regardless of its merits and short comings. If you ever need to move to a pro studio, you can always burn your tracks to wave one at a time and transfer them over the PT.
I've used Pro Tools LE, Cubase SX, Cubase VST/32, Cubasis and N-Track. I've played around with CakeWalk Pro Audio 9 a while back, too, but never really used it. Of these, I'd say your most powerful option is Cubase SX. Its flexible, fairly easy to use, and there are lots of decent plugins availible for it. Its also based on the Nuendo audio engine, for what its worth.
Your cheapest option is n-track. I think its about $60US and offers you all the flexibility of the big shots, but isn't as stable. I typically recommend starting with this one before shelling out for a more expensive program. Learn what you want to do with n-track and buy the right program when the time comes, if it comes. I used it for a year before going Cubase due to a hardware upgrade.
All the talk about digital vs. analog summing is amusing, and true enough, but fact is that most of us don't have the cash or hardware to route 24+ tracks into seperate, high quality analog channels. Since you are mixing in your computer, rest assured that most folks won't be able to tell the difference and you'll get plenty good sound quality of whatever program you end up using. They all work about the same, unless you want to consider some very expensive options.
Take care,
Chris
