Cubase to Nuendo
  • Thread starter Thread starter ThunderDrum
T
ThunderDrum
I'm getting problems trying to use a project from Cubase2 in Nuendo2 the files are in the project but no sound!!!
Any1 can tell me a proper way to import?
TNX!
It should just work. Make sure the soundcard configuration didn't get changed when you opened up the cubase file.
What Farview recommended sounds like the right solution. If you are seeing your meters working on your master output in Nuendo, check to make sure that Nuendo is trying to address the same (or at least proper) soundcard channels.
is nuendo otherwise working properly??? you can open and record new project??
