M
mrdee
Hello everyone,
I am using Cubase SX3 and have now installed an Audigy 2 ZS Platinum into my PC.
It sounds fine, however there are one or two issues I'd like to clear up.
When I use the "ASIO DirectX Full Duplex Driver", all is well, except that the Total Input Latency is a bit high (298.667 ms), Total Outpu Latency is fine at 42.167 ms.
I also tried using the Creative ASIO driver, in which case I get excellent Latency (22.083 ms In, 20.000 ms Out, and I can even go lower), however, I then find my Sample rate changes to 48000 Hz and I only have this rate available, it looks to me no change is possible, while with the other driver, when I go to "Project ->Project Setup" I get a drop-down list with selectable varying sample rates between 11200 and 96000 Hz.
Could anyone tell me if there is something wrong with the above and whether or not it can be corrected, or is it OK to work with a sample rate of 48000 Hz constantly?
Any help will be much appreciated.
TIA,
Mr. Dee.
TIA,
Mr. Dee.
