P
pumpkin
Hi Please help me with this
For some reason, I'm unable to use the MIDI between Triton and Cubase correctly
I have one MIDI track in Cubase SX, which is used for channel one. I recorded it while I was in program mode in Triton. (In the Global setting, the CH was set to channel 1)
It worked with no problem
I could record again and playback with no problem
Problems came when I wanted to add another instruments using Triton. I swiched to SEQ mode, and set the same instrument as the one I used in Program mode in track one (ch1). Then I selected track 2 from the pop up menu, and selected another instrument for track 2 (ch2). I was trying to playback my first recorded MIDI track while playing something using ch 2 in Triton, but the problem is that for some reason, Triton would playback the instrument I selected in track 2. It's supposed to playback the instrument in track 1 (ch1) since in SX, ch 1 is selected for that track.
Also, after I selected a different instrument in ch2(track2), the instrument originally selected in ch1(track1) would be change to the same one in track 2.
It just seems like I can't select instrument for seperate channels, like they don't listen to my command, and like they're connected or some sort, they would only agree to play one instrument.
My Triton's Setting: Global off.
Convert Position
reMIDI
Bank Map : Korg
Can anyone please tell me what I did wrong?
Thank you so much
I'd be really appreicated
Convert Position
Bank Map : Korg
Thank you so much
