C
cvenaccio
I am currently running Cubase SX on P4 1.4Ghz system with 256 RAM and W2K. I am using the M-Audio Dleta 66 card with the Omnistudio break out box for recording. The variable signal levels are all set at 'Consumer' (input and output) for the M-Audio card. I am also using a Midisport 8x8 router.
I have input all the parts I want for my composition via MIDI into Cubase SX. Whe I play the MIDI tracks back, the synth sounds fine. Then I try to record my MIDI tracks to audio. I record one patch at a time to give me greater flexibility in mixing. The volume level on my synth is about half volume, low enough that the input lights on the Omnistudio barely bounce into the green and never bounce into the clipping range (the orange clipping lights never fire). However, when I am recording an audio track, I get some random crackling or popping that completely destroys the track. I can't isolate the reason why. I have rebooted several times to no avail and my synth is running it's most recent OS.
I am using the stereo inputs into the Omnistudio to link my synth's audio to the PC. When I record the audio, I push the 'line send' button on the back to send the stereo inputs of the Omnistudio to the line inputs for recording.
I am out of ideas as to what the problem is. Any help is appreciated.
