Cubase SX 3 buzz glitch
  • Thread starter Thread starter Dr Shock
D
Dr Shock
I have been having a problem which has me baffled and wonder if anyone can help. I am doing midi mixed with audio and here is the situation. I bring in the midi file(s), then I import the audio file(s). I then automate the mix and everything seems fine. At this point, I run the audio and midi both out to my mixer and reroute them into a new audio track to record a stereo mix of the audio and midi. As it is playing back and recording to the new track, a glitch that sounds like a buzzer or buzz saw ( digital sounding ) occurs at the same time every time, let's say right around the 5 minute mark. If I stop and start the playback about 10 seconds before the glitch time, it will play and record perfectly with no glitch. Only when I start playback at the beginning does it glitch at the 5 minute mark. My project is set up for a 10 minute length and my beginning, end markers are set appropriately. Any help would be greatly appreciated. Another case is in a different audio/midi project where there is a definite level increase that occurs at the same place each time if and only if I start playback from the beginning. Once again, if I start to playback/record from let's say 15 seconds before where the level increase occurs, it does not happen.
thanks for any help
Dr Shock
