Cubase LE FX
  • Thread starter Thread starter apl
apl
apl
Stand Up Comity
I put Cubase LE on my computer over the weekend and was messing with an old Cubasis project. Can I set up the FX with different settings for different channels? For example have one compressor setting for vox and another for bass?
If you use it as an insert it should work. If you set it up as a master effect then you can't.
  • Like
Reactions: apl
Yeah, as EdWonbass says, you can set up multiple instances of an effect for different tracks. The limitations are really going to be the plugin itself (whether multiple instances are supported -- they usually are) and your processor. As an insert, you can put the same compression plug on different tracks with different settings. As a send or mastering effect, you'll have to set up multiple instances of the plug (one for each setting you want). IIRC, LE doesn't offer many sends, though, so that will be a limitation.
