Cubase is set up around what Steinberg called VST or "Virtual Studio Technology". If you know your way around an analog mixer, you should have no trouble figuring out the mixer and channel edit (that's what the "e" stands for) windows. You get a four band parametric EQ, inserts, sends, a fader and a meter (with other nifty features like channel input gain and polarity reverse, etc) standard with every channel. I personally find the EQ on every channel handy because it becomes a pain to have to insert one every time you need to like in Pro Tools. Plus they take up processing power in plugin form and the EQ's in Cubase are virtually footprint free.
The first thing to know about editing in Cubase is that it is all non-destructive. This means that the original file is unaffected by any modifications you make and when you process or bounce a track it is stored to a new file. All files are stored for retrieval or management in the audio pool (ctrl-p).
The standard hot keys (key commands) for editing tools are as follows (all numbers are the sequential numbers above the qwerty keys):
1 - Select Tool, Slip Tool, and Warp Tool (alternate between them by pressing "1" in succession)
2 - Range Tool
3 - Split Tool
4 - Glue Tool
5 - Delete Tool
6 - Zoom Tool
7 - Mute Tool
8 - Draw Tool
9 - Play Tool
So you can accomplish just about any editing operations with those and it's a good start to learn to switch between them seamlessly while working. My left hand kind lives in this area of the keyboard because editing also involves using the "shift", "ctrl" and "alt" keys quite often. Other things to know is that "J" turns snap on and off, "F" toggles the program to scroll the screen with the cursor during playback, "V" bounces an edit to a new file, and "G" and "H" zoom in and out.
These are the simple key commands that are essential to navigating around Cubase. Get to know them well.
Hope that helps.
Cheers
