Cubase and Dimension Pro
  • Thread starter Thread starter Skaf
is this a VST, a plugin? if so, i believe it is possible, companies make their plugins compatible with Cubase nowadays
It's a standard vst plugin.
As long as your host DAW supprts vst2.4 and onwards, which Dimension Pro is, then it will be fine.
The only issue is some of the included plugins within Cakewalk that are locked to Cakewalk itself. As Dimesion Pro is a seperate install you wont have an issue.
Well as long as you're on Windows.
Dimension Pro hasn't been compatible with osx for the past 6-7 years (3 os versions) as Cakewalk
had some kind of spat with the installer programmers and would never fix it.
Shame, I really liked the lite version on XP and would have bought it if they'd fix it.
