Cubase 7 Meter Bug I think
  • Thread starter Thread starter denlig
D
denlig
Hello,
When i record audio,the input meter is +3.4db higher then the monitoring track and recorded track. I can insert a audio file from a CD onto a stereo track and the inserted stereo track plays +3.4db higher then the stereo bus track with no added plugins or eq on the track. I get distortion sounds at low mic pre levels with any peaks pass -12dbfs.
Last night while experimenting with Cubase, I deleted the stereo bus and added a new stereo buss and assign lynx aurora output 1&2. This fix the problem and the play back stereo audio track plays at the same levels as stereo mix bus.
I dont know if this is a cubase 7 bug or a lynx aurora bug but by deleting the stereo output and adding a new stereo output this seems to fix the problem.
Has anyone had this problem ?
denlig
