Cubase 7.5.10 update now available.
  • Thread starter Thread starter jokerone
This update kind of sucks on OSX. Having more crashes than I used to.
Should have stuck with 7.4.0 Grrrr
Hello Guitargodgt,
Can you specify a little bit more, can you reproduce some of the crashes?
Best regards,
GN
The slate thing has always been there. I posted that bug in another thread but I'll repost as this always happens without fail, but I will put up my new bugs that also apparently always happen.
This is all legitimately owned software btw:
1. Have a few drumtracks.
2. Place SS trigger on insert of multiple drum tracks.
3. Play song.
4. Remove instances of trigger (latest version btw, I did check).
5. Removal of last instance will always without exception crash cubase.
New bug as of this version:
Just one step apparently, but it crashes cubase and it didn't used to:
1. Have audio track, try to insert URS S series EQ (vst2 plugin if it matters)
And this bug is hard to reproduce so I'll try to explain what happens and I'm not sure if it always happens or wtf goes on. The VSTi doesn't seem to have any holding on this one though it can be a Stienberg plug or a 3rd party.
1. Have midi editor piano roll open.
2. Move many notes up or down in pitch.
The work around has just been to get used to the new SSL clone eq I have that came from buying komplete 9 in November. But I have to admit I was really used to the ol URS.
OSX 10.7.5 on mac intel 2x2 GHz dual core intel xeon with 8 gigs of RAM.
All of my plugins except for VST3 and stock cubase plugins are in the location HD/Library/Audio/Plug-Ins/VST/-Plugins and then I have sub folders to categorize them further such as chanel strip, eq etc...
Hello,
It seems that your problemas are when using third party plug-ins, have you reported this to Slate Digital?
I will pass this info to the debs, but its seems that it will take longer than it seems and probably has to get fixed in conjunction with the 3rd party developer.
Best regards,
GN
Right the slate digital bug has always been there (I think I started using trigger with version 5).
The URS one is new to version 7.5.10
The midi one has always been there as far as I know, but it's hard to get it to reproduce. Like I said, doesn't matter what plugin I use on that one.
