Cubase 6 hangs when loading second instance of auto-tune.
  • Thread starter Thread starter mikel33
M
mikel33
Hello,
If I have an audio track with auto-tune enabled and try to load auto tune on a second audio track, the program hangs (spinning wheel). It also doesn't allow me to open any previous projects in this project folder with auto tune enabled. I had to load Cubase with the plugin renames, create a brand new audio track with no plugins and the program loads the project.
I get tons of this exact error in the log:
Cubase6.exe Version 6.0.5 Build 357 - 30.7.2013 0:57
Timestamp is 4e8f28ad (Fri Oct 07 12:28:29 2011)
F:\Program Files\Steinberg\Cubase 6\Cubase6.exe
Exception code: C0000005 ACCESS_VIOLATION
Fault address: F8200B90 01:000BFB90 F:\Program Files\Steinberg\Cubase 6\VSTPlugIns\Auto-Tune+Time_VST.dllBytes at CS:EIP:
88 51 54 44 88 41 55 44 88 49 56 c3 cc cc cc cc
4c 8b dc 49 89 5b 08 55 56 57 41 54 41 55 41 56
Thank you.
I will update Cubase and see if it helps. I'll also try the buffer size increase. I just installed those Auto-Tune drivers so they are the latest (got them from Antares site).
If that doesn't work is there anything else that could resove the issue?
It crashes as soon as I click Auto-Tune for the second audio track (before I save it)... which in turn doesn't allow it to load that project any longer, as long as the original instance of Auto-Tune on Audio Track 1 is present. Odd how the project doesn't load, even though the second track isn't present in the latest save.
