Cubase 5 - tempo help please!!!!
  • Thread starter Thread starter magictorch73
M
magictorch73
I am running reason through cubase 5 - have a midi track with many tempo changes done on the tempo track. When I play it back it all sounds perfect, slowing down etc exactly as I intend - however, when I export to audio, the tempo changes are no longer there - have done this several times in the past and have never had a problem. Please please please can someone advise!!!
Thanks in advance
I have never used the tempo chs ange function in cubase, In the export audio window is there an option thaty says export tempo change or something like that
Thank you for taking the time to reply, appreciate that - I don't need to export the tempo track on its own, I just need it not to disappear when I export my track to audio, ie make an mp3 of the track I made. Any further ideas?
I'm not exactly how you have it setup but keep in mind the difference between having your tempo track to be fixed on a tempo or have the tempo track on through your entire project. It'll have a fixed tempo if you don't have the tempo on when you export it.
