P
Ptron
I've been having DC offset problems with my recordings. Most likely due to my cheapo stock sound card, I'm told. It's a soundblaster audioPCI 64D made by Ensoniq. I've downloaded and tried using the DCoffset plug-in from http://www.analogx.com which allows you to manually shift the offset of a previously recorded file (it says it can be automated but I can't get it to work) but don't you lose head room if the music isn't recorded with the proper DC offset in the first place? Are there programs out there that fix the offset before you record? It seems like overkill to buy a fancy soundcard to fix this. I don't need multi-ins because I mix to stero first and I don't need 24bit because my software (dart pro)only handles 16bit.
