Copying plug ins between tracks?
  • Thread starter Thread starter bfsuk
B
bfsuk
I'm currently in the process of mixing my bands album which we've recorded ourselves and was wondering ... is there any easy way to copy the plug ins from one track to another without opening up each track and going through each putting in the plug ins?
I know obviously I won't want each track to have exactly the same plug ins on each track, but just as a starting point?
I know you can create templates but is it possible to do this for plug ins to use after the audio has been recorded?
I'm using Sonar 6 by the way.
Thanks,
James
Seems like you'd be looking at either project or track templates with things preconfigured, but that would be before you've recorded. You're looking for a way to by-pass the 'insert procedure, or saving presets?
The only way I know how is to hold the CTRL key while dragging a plugin from one track to another. That will let you copy one plugin at a time. And it will copy the plugin settings too.
