shAkEz_gk
I didn't come up with this, but it works for me.
Following this can help give you alot better sound.
1. Silence & Delete
- Edit > Delete Selection
- Effects > Silence
2. Noise Reduction
- Select 0:01 of hiss
- Effects > Noise Reduction > Noise Reduction
[Get Profile from Selection]
-- Noise Reduction Level: 100
-- FFT Size: 4096 Points
[Select] Remove Noise
-- Reduce by: 80 dB
-- Precision Factor: 7
-- Smoothing Amount: 1
-- Transition Width: 0 dB
[Close]
- Edit > Select Entire Wave
[OK]
3. Compression with Native Waves Gold
- Effects > Direct X > Waves > L1 Ultramaximizer+
-- Input: 0.0 dB - 0.0 dB
-- Threshold: -8.0 dB
-- Out Ceiling: -3.0 dB
-- Release: 10.0
-- Atten: 0.00
-- Quantize: 16 Bits
-- Dither: Type 1
-- Shaping: Normal
-- Domain: Digital
4. Dynamics Range Processing
- Effects > Amplitude > Dynamics Processing
-- Preset: RealAudio® Compander
5. Light Reverb
- Effects > Delay Effects > Reverb
-- Total Reverb Length: 1000 ms
-- Attack Time: 60 ms
-- High Frequency Absorption Time: 500 ms
-- Smooth/Perception/Echoey: 15
-- Original Signal: 110%
-- Reverb: 10%
-- [Check] Combine Source Left and Right
6. Hard Limiting with Native Waves Gold
-- Threshold: -9.0 dB
-- Out Ceiling: -1.0 dB
-- Release: 100
-- Atten: 0.00
-- Dither: Type 1
-- Shaping: Normal
-- Domain: Digital
7. Antares Microphone Modeler
- Effects > Direct X > Antares > Microphone Modeler
-- SOURCE MIC Settings:
--- Source Mic: bypass mic
--- Proximity: off
--- Input Gain: 0.0
-- MODELED MIC Settings:
--- Modeled Mic: Nueman U 87
--- Low Cut: Off
--- Pattern: Cardiod
--- Proximity: 10.0 inches
--- Output Level: -0.5
-- Preserve Source: Neither
-- Drive/Tube Saturation: 0.0
8. Smooth Echo
- Effects > Delay Effects > Echo
-- Decay: 40%
-- Delay: 240 ms
-- Initial Echo Volume: 3%
-- [Check] Lock Left/Right
-- [Uncheck] Echo Bounce
-- [Check] Continue Echo Beyond Selection
-- Successive Echo Equalization
--- 86: -2
--- 172: -1
--- 344: 0
--- 689: 0
--- 1.3K: 0
--- 2.9K: 0
--- 7.3K: 0
--- 22K: 0
1. Silence & Delete
- Effects > Silence
2. Noise Reduction
-- Reduce by: 80 dB
[Close]
[OK]
-- Release: 10.0
-- Atten: 0.00
-- Dither: Type 1
-- Shaping: Normal
-- Domain: Digital
5. Light Reverb
-- Reverb: 10%
-- Release: 100
-- Atten: 0.00
-- Dither: Type 1
-- Shaping: Normal
-- Domain: Digital
--- Proximity: off
--- Input Gain: 0.0
--- Low Cut: Off
8. Smooth Echo
-- Decay: 40%
-- Delay: 240 ms
--- 86: -2
--- 172: -1
--- 344: 0
--- 689: 0
--- 1.3K: 0
--- 2.9K: 0
--- 7.3K: 0
--- 22K: 0
