G
gitrokr
are there any unthordox ways you use your compressor other than limiting that peaks and all that??? is there any ways you use it more like an effect?? what settings do you set your compressor too?
gitrokr said:are there any unthordox ways you use your compressor other than limiting that peaks and all that??? is there any ways you use it more like an effect?? what settings do you set your compressor too?
Fela said:Use the key input.
I mean really.
*smug grin*
Quite true, but anything you put there effects the compressor. Boosts, cuts, or with other signals.Jblount said:I thought that the sidechain with a eq was to de-ess?
Jblount said:When you side chain a eq, dont you boost the frequency that you want to take out, so that it compresses that frequency more than the others. I am trying to figure out how that works.
fenix said:you cut the frequencies you do not want to compress.
