converting bit rates
  • Thread starter Thread starter michaelq
M
michaelq
hey. i'm recording on my computer and left my sample rate at 44.1 as i was told to do, but was told to change the bit rate to 32 bit (float). Apparently this will never burn onto to a cd, or if it does wont register in a cd player so does anyone know a program that converts from 32 bit back to 16 after its all done? thanks.
The software you are using to convert to 32 bit should allow you to convert back to 16....what are you using ?
i' m using cool edit pro 2 ... i just found a manual online for it so i'll check that to find out. thanks.
Yes cool edit will allow you to convert the sample rate.
