T
twsknight
Hi all,
I'm a long time lurking and very occasional poster, but now that I'm on the cusp of a house purchase that contains a double garage! Better yet, my darling wife is more than happy for me to convert the garage into a studio. We see this as a long term project, but I'd like to get something up a running sooner rather than later, so what I'd like to is basically take the garage and make it feel more like a real room.
So I'm thinking of plasterboarding the brick work and maybe plastering over that, if that's the done thing! I've also been informed that you can use plasterboard to make the ceiling solid as its all metal framework at the moment.
There are a couple of things that are confusing me:
The floor, at the moment it's just cement, and its a bit uneven with wear and tear. What do I have to do to make it more like proper flooring. Level it with cement I guess is the first job, but what next? Also should I do that first?
Also, the plasterboard will be away from the walls as there are some brick square columns that stick out a little bit further from the wall. Is there something I can use to fill the gaps that would work as both insulation and soundproofing? The sound proofing doesn't need to be state of the art as we're hoping that one day we'll have it professionally converted into a real room. Get windows put in and everything.
What I'm planning will still have the facade of a garage outside but inside will feel more comfortable to be in than a garage and hopefully not be as exposed to elements so I can put my guitars in there without worrying about the temperature having adverse effects on them.
Apologies for the long post, hopefully that makes sense!
