B
Bulls Hit
Anyone using control surfaces with Cakewalk products? Which ones?
Do they work via usb, or do you need a midi connection?
1. Sonar records the automation by drawing envelopes.Bulls Hit said:Moskus when you move the faders (adjusting the levels), does it draw an envelope in Sonar, or does Sonar record the automation?
What functions do you still need the mouse for?
Also, will it work via usb or do you need a midi connection?
ws6snake-eater said:I have sonar 4 and a firewire port. I am looking at purchasing the 1884. Will I still need to buy a multiple input sound card (currently using soundblaster live)? Currently I can only record one track at a time. Does the Firewire connection send the audio and the DAW stuff? Sorry I'm new to all of this stuff. I've only recorded old school analog.I've been reading a lot about it, I just want to make sure that this will make my studio/computer intergration complete.
Bulls Hit said:Is it possible to record from both the analog and adat outputs at the same time, so you're recording 16 inputs? Can the adat sync with a regular soundcard or do you need a special adat card?
vestast said:You can throw that soundblaster out the window. The 1884 is a complete solution for recording. 8 Analog inputs 8 analog outputs, inserts on each channel, 4/4 midi connections and a controller for your software.
The documentation says Up to 18 simultaneous inputs although I'm sure there must be a compromise in quality.
Not sure about the adat question..
