B
Blueskicker
What type of plexiglass window would be suitable for sound isolation for drums?
brainofj said:I work for a sign company in Scotland. We use all different types of plastic materials. Plexiglass is another name for Acrylic. I used 2 15mm thick pieces of Acrylic for a control room window which worked quite well. As the other guys are suggesting laminated material, look for a material named Polycarbonate. This is much more tougher than Acrylic, the kind of stuff if you throw a brick at it, it will bounce off and probably knock you out. I will have to try the Polycarbonate myself and see if there is any difference.
Hope this helps you out.
