M
mrplow
Hello, can someone help a fellow musician that's new to the Home Recording world?
I'm thinking of buying a control surface, specifically the Behringer BCF2000 or the Mackie Control Unit, and have a questions:
1) Is a soundcard w/MIDI required to use a control surface? Right now I am using an Omni Studio (Breakout Box w/Delta 66 Card) as my main recording card, and it does not support MIDI. However, I also have a SB Live! I've left in there that can support MIDI. Is it still possible to use the control surface to mix tracks recorded through the Omni Studio?
2) Is there a control surface that has the full knob set (can't think of a better term) for all the EQ, trim, etc. functions typically seem on a mixing board? I basically would like to see all the EQ settings for each channel at once, and not have to toggle between channels using buttons to adjust different EQ knobs.
3) Is there are a control surface that doubles as a digital mixer?
4) When using a digital mixer, is it possible to just connect an external drive directly to mixer for recording (sans computer).
Thanks,
Ron
Thanks,
Ron
