W
woody777
Hi guys,
Here's my setup:
Dell Inspiron 1501 w/ Windows Vista 32-bit
SIIG FireWire 2-Port ExpressCard w/ TI chipset
Focusrite Saffire PRO 10 io
Western Digital My Book Premium 500GB HD
Reaper
I'm getting a constant static sound during both recording and playback. The static is only there if sound is going in or out of the Saffire. And Reaper doesn't need to be running. I can plug my guitar into the input of the Saffire and strum a chord and get static. And any playback creates static, but only when audio is actually playing. If there is a pause or break or if I mute the tracks, the static will drop out.
I've tried uninstalling and reinstalling all of the components several times. I'm using the most up-to-date drivers for everything. I ran the Windows Vista Optimization Guide found here: http://audioforums.com/windows-vista-optimization.php.
It seems like the issue is between the SIIG firewire card and the Saffire PRO. Sometimes the lights on the Saffire PRO will flash continually, as if it's losing and searching for the firewire connection. And when I first turn on the Saffire PRO, there is a very loud static sound as the connection is being made. It eventually fades out when the unit connects.
I've tried increasing and decreasing the latency - neither has any effect on the static. I've tried to disable my laptop soundcard and wireless card - no effect. I even downloaded a program to change the latency on drivers and decreased the latency on my video card (it's a CPU hog!) and that had no effect.
And my headphones are working fine... I tested them on my home stereo... no static. Both headphone jacks and the output jacks on the Saffire PRO all yield the same results.
I actually accidentally ended up with two SIIG cards. Both cards do the same thing. Although when I first plugged in the second card the unit functioned flawlessly for about an hour and then the static returned.
Could it be that I just got a bum Saffire PRO? Sorry for the long post... I'm frustrated!!!
Here's my setup:
Reaper
