J
Jack Real
Hi
When I listen to one of my mix, the level of my bass is not constant from notes to notes. It is not a matter of playing the notes at equal level because the keyboard has a feature that allows all the notes to come out at the same level. It's more like some notes (one in particular) come out stronger in the mix than the others. My keyboard doesn't have a function that allows me to set the output level for each note so I'm stuck with 2 options:
1) Increase the dynamic range setting of the keyboard and play the keyboard so the notes are more even in the mix or
2) Apply parametric EQ on specific notes at the mastering stage to even out the notes
Is any of you facing the same problem with the bass level in their mix ? If yes, what is your solution ?
Thanks,
Jack Real
Thanks,
Jack Real
