J
Judge
Now that i've worked out wat i wanna get (well almost) before i go out to buy it i need to make sure everything will work together.
Now this is the way i wanna hook everything up can you please tell me if this will work
i wanna plug my sm58 to a pre amp (joe meek mq3) then put that through to my vs-880 and then plug that into my soundcard (midi man audiophile 24/96). now thats my input covered i think i should have no problem as far as that goes
now i wanna connect a pair of event 20/20bas into the soundcard as well as the vs 880. will i have enough outputs for this and can i do this with thisd sound card???.
side note. the reason why i need the sound card needs to have an output to the vs-880 is cos the beat is being produced on the comp.
ay bit of help will be helpfull
