D
dogbox
Hi, just confused about the functionality of a Behringer amp800, 4 channel headphone amp. The way the amp appears to work is there is an stereo input A, and a stereo input B, then you get an individual balance and level pot, for both A and B....you pan one left the other right, and set the levels accordingly...what my problem is, it appears when you plug in a headphone you have to chose A or B, NOT A and B...does that make sense?? Is that normal behaviour for headphone amps in general??
Call me crazy, I just assumed that the point of having the 2 inputs was so that you could blend both. For example, I want the mix coming from my daw via a mixer into channel A, I want the output from my Roland Edrum kit in channel B...I want to record the midi out from my kit back to my daw, but I don't want to monitor through the daw, rather I want latency free monitoring through the headphone amp??? Is this doable?? The diagram is printed on the front of the headphone amp, shows if the Botton is pressed in , then you get to hear channelB, if left un-pressed (light off) you get channel A...I confirmed, this is what happens exactly...there dos not appear to be a way to blend both signals...what am missing here. Also want to know why they go to the trouble of having both input channels having their own level and balance pots but they can't operate in unison...Theres some other obvious use case that exists, that I can't figure out. It's probably to do with the recording multiple people simultaneously. Anyone???
