Confused about Preamps
  • Thread starter Thread starter JBr33zyMusic
J
JBr33zyMusic
I understand that Preamps change the mic's quality but I don't understand how to connect it to a mixer. What would I need to do that? I have an Alesis Multimix 6 usb and I was looking at the MAudio DMP3. What exactly would I need?
Ok, According to their site, your unit has "Six 1/4-inch line-level inputs, and two XLR inputs with gain trim"
The xlr inputs go through built in preamps, while the line level inputs do not.
Your dmp3 has a line level output, so you connect its output to one of the six line inputs on your multimix.
The signal is balanced so you're looking for a TRS cable.
So I plug my mic into the pre amp, then take the TRS cable and connect it to my interface?
Yup. The pre-amp does exactly what it says on the tin...it amplifies the microphone level signal (generally around -50 to -60dBu) up to line level (around 0dBu) which you can then plug into any live level input on a mixer or interface. This would be with a TRS to TRS cable on the vast majority of pre-amps, mixers and interfaces though there are occasional exceptions.
