Condenser mic volume very low, please help
  • Thread starter Thread starter El Baroda
Hi Chili. I've got the Samson S-mini mixer as noted above. I think this is the entry level in the S series. Thanks.
To get 48 vdc out of a lower dc voltage, the manufacturer would use DC-DC converters, also called switching power supplies. Pretty common and they are used to increase dc voltage.
For the OP, you should be more specific about which model samson you have. There seems to be several different, but similar models of the S-mini. Read the manual and see waht it says about phantom power.
See, I knew I wasn't sure about this. Thanks for jumping in Chili. :)
