Condenser Mic on Bass Drum
  • Thread starter Thread starter Seafroggys
Seafroggys
Seafroggys
So my AT4047 came in, and while I bought it so I can have a solid decent vocal mic, I put it to use as a bass drum mic. I'm a fan of minimal drum mics, so while I have heard of the ol' dynamic at sound hole and condenser 3-4' back trick, I want to do just the AT4047 on the bass drum, without any other mics on the drum (and I know this has been done before).
What would be the closest I should put the thing? I tried 8" in front of both the center and the sound hole today, and got pretty good results (after retuning the drum a bit). But can it be done closer without damage, or should I just stick to 8"? Also, it picks up my cymbals quite a bit, so maybe a corridor of blankets to help cut down on the highs? But I don't want to suck the life out of the bass drum either.....
You can always try the 'tunnel' approach to help with that bleed in the kick mic. I have used it many times even tho it looks quite silly. Proven by my pix. :)
I wouldn't put it close to a hole as the wind blast could damged the diaphrame. However I've put LDCs right up within inches of the resonant head with great results and no damage.
Not to mention the wind blast sounds of ass. I have had best results using the combo of dynamic inside pointed at beater, LDC 3 0r so inches from outer head just off center. I have been experimenting with the subkick build at the end of that silly tunnel with decent results, tho lately I am getting better results with enhancing it all with SS Trigger. For less than the cost of a cheap mic, it really takes the guesswork out of the equation. Maybe I'm just lazy, but damn, I cant argue with a perfect kick drum with no bleed. :)
I know what you mean Jim. Once you go trigger you'll never go back!
Yeah. Seems the best idea. I am mixing a project now for some friends who recorded in their rehearsal space. The kick drum track was destroyed with clipping and totally unusable. It was however a perfect input for Trigger. Saved the project.
I understand why triggers and samples would be desireable but I love the challenge of getting what I can get out of the drums with mics.
Cool, so if its in front of the sound hole, maybe keep it back at 8", but if its more centered I can bring it closer. I'll try using blankets too...another thought is I like how the OH's pick up the very top end thud of the bass drum and it actually adds to the overall sound. Hopefully I don't lose that.
