Comuter/Software/Stability Question
  • Thread starter Thread starter Shakkalath
Shakkalath
Hello all, as you can tell I am new to the board, and I am new to digital recording, however I plenty of studio/engineering time on the analog side albiet along time ago!
I have searched the forum archives and found some answers that were close but not really what I have a question about. So here it goes...
First lets get the computer specs out of the way, it is a Dell Optiplex 240 with 512 megs of RAM, Intel Pentium 4 1.8 ghz cpu, 80 gig hardrive running Win 2000. This computer is what I run my business off of and I am extreemly concerned about crashing it!
With that said, my goals are just to produce songs by myself and maybe one other person at the same time, using acoustic and electric guitars. I do not see my compositions at least at this time, requiring a "boat load" of tracks but that could change down the road.
When I first started researching this idea, I was thinking about getting something like Cakewalk Home Studio getting a interface and doing everything on the computer, because I liked all the options/potenntial available. All was fine until I started digging a little deeper and realized some of the potential problems that can crop up with computer recording.
So then I started looking at a small 8 track recorder like the Boss BR 8, simple and easy to use, no elaborate computer set up etc. At this point that I what I am thinking about starting with. After reading some posts here about combining the two ideas, I have come up with some questions.
First, is software like Home Studio less demanding on a computers resources than the more expensive Cakewalk products?
Second, if I record the tracks on the Boss, and mixdown/master on Cakewalk am using less of my computer resources thus hopefully reducing the chance of a computer crash? Also going this route, would I be able to do this with out having to add an additional hard drive?
I am sure these questions have been ask before and I apologize to those you that are annoyed by this, but I searched the forums until I was blue in the face, and finally just decided to post.
Thank You in advance for your time.
Sincerely,
Todd
hi todd, welcome to the board.
for your needs ( you said you were looking for a few tracks, and maybe 2 at at a time) your computer will work fine. That is a decent systme and i wouldn't worry about it crashing. Do you plan on doing any midi/synth work? if not, i would suggest looking at adobe audition. it does not really support midi but is a nice program for audio recording. I use cakewalk sonar 3 on both my new computer and on an older system that pretty much matches the specs of yours, and everything runs fine. Cakewalk programs have midi capabilities and that may be something you don' twant/need.
it's your call but i would recommend recording the tracks on your computer insted of an 8 track recorder. This will require a soundcard with at least two inputs (and preamps if you don't already have any). For a great starter soundcard, check out the audiophilie at www.midiman.com or the 0404 at www.emu.com
Dar,
Thanks for the input, as far as the MIDI thing goes probably not at first but I would like to be able to grow into it should I decide to. The Emu 0404 looks pretty interesting! Thanks again for the help
