bthiesson
cranie said:If it was a graphics card or memory the motherboard would still give a bios post beep. the ONLY things that will cause it to NOT beep at all is if the motherboard is shorted to the case (mine does this on a regular basis and I just flex the board to move it a little and all is well again)
Other than that I would look at the power to the motherboard itself (are the board fans all spinning?)
if not the power supply/connection to the MB could be the cause.
After that you're looking at the CPU but I seriously doubt it's that.
BINGO....I gave a pull on the side of the board, and it came back to life.
You da man crainie....Thanks so much
