Computer fans
  • Thread starter Thread starter whattaguy
W
whattaguy
Which fan makes the most noise?
1. Stock P4 CPU fan
2. Stock case fans
3. Enermax Power supply
4. Video Card
I had 3 cpu fans that came stock with the case. I pulled one out, but I can hear no audible difference. What's the culprit?
Thanks.
Can't say. No two fans are the same. There are videocard fans that produce >50dB. Others are barely audible.
Usually the cpu fan will make the most noise, single handedly.
If you've got a fan up front that's be 2nd most noticeable next to the CPU fan, usually.
Video Card fans as long as they are stock usually have no noticable change. Unless it's say like the new GeForce FX card that takes up two pci slots of it's own /:
I've got 6 fans in my case (one on the CPU, two on the power supply nice quite enermax whisper supply-that it truly does, one on the video card, and three 80 mm case fans) I've also got a drive-bay with knobs to let me control the case fans, and my cpu fan has a speed adjustment switch as well. I can stick my head in the case and barely hear the video card and power supply fans combined.
It all depends on what size your case fans are, and who makes them. They will vary, you can get one 40 mm fan from some place and it will make a noise of say 30db, while one from another company of the same size and style will make 40db.
It all adds up.
But in your situation from what you listed I'm gonna say it has to do with your case fans and cpu fan.
As enermax power supplys are pretty quite, as are MOST video card fans are as well.
You should have 4 (5 if you have a videocard that needs one) fans in your case minimum if you want a good condition airflow in your computer, if possible see what fans came with your case try to get some really quite ones.
You could also get a better fan for your cpu, one with optional speed switch, and get some nice thermal compound for the cpu so you can get even cooler cpu temps and be-able to run your cpu fan at a lower speed.
I wouldn't think your case noice would be that loud from what you have listed, but hey. You can go spend a few hundred if you want to go water cooling /: If the noise it that big an issue.
Well, good luck.
My case fans (now two) are Power Logic model #PL80S12M
My video card is a NVidia Geforce 3 Ti200
I'm suspecting the cpu fan
Also, concerned about heat, I ran a benchmark and got less than 100 degrees on both the case and the cpu with only the two remaining.
Power Logic case fans:
Power Logic 80 x 80 x 25mm that turn 2,900 RPM moving 39 CFM at 32 dBa and come with extra long power cables.
you could get quiter fans...the 80mm stealth fans I recall were like 20 or 21 db
but the most influencial noise reduction will come from another cpu fan.
Not much to do about a video card fan as mentioned they are very quite, I've got a GF4 ti4200, so can't imagine the GF3 ti series would be any louder than what I've got running.
DOn't know what would be the most effective cpu fan, that's effective at cooling but will bring down your noise level.
I've got a Thermaltake Volcano 7+, on the med setting. With all my case fans turned down at least the two intakes, it makes a tiny bit of noise. I mean if it's late at night in the dead of silence you'll notice it. the low setting from what I recalled when I used that it was pretty damn quite.
I'd check around for a new cpu/heatsink, if you want message board input on that other than from here the guys over at the pcclub.com forum will do you well I'm sure of. I'm sure they'll try and get you to buy the item from pcclub, but everyone over there is helpful and will get you some good info.
_Mike
