gecko zzed, I like to know more about In the box recording. It could be that I might end up doing my recordings that way instead of OTB. What kind of audio interface are you using ? I ask that because the PreSonus Firestudio Project audio interface use's the jetPLL that dgatwood mentioned above. Thank you for your help.....
I don't know anything about jetPLL.
I use a Presonus Firepod (which, I believe, is now the FP10). This has eight mike inputs (plus other stuff, midi, SPDIF etc.) and eight lines via firewire into the PC.
When I first started looking at digital stuff (mid-nineties) I ended up with Logic Audio and an eMagic PCI card. At that time, my brain was still thinking in conventional recording practices: faders, knobs, patchbays and hardware FX. When getting the interface and software, my questions at the time related to how I could match my bits of rack-iron with the new digital gear. It took me a while to realise that I had to adjust my thinking and revise the whole recording 'business processes'.
Once I made this step, I quickly became comfortable with a different way of doing things.
At times, I do fly things out of the box . . . for example, I might record a clean guitar directly into the PC, then send this via an output into an amp, then mike up and record the guitar-through-amp sound.
I still use an external mixer, but this is mainly for routing purposes rather then for mixing as such, For example, with the Firepod only having eight outs, I sometimes have to rationalise the inputs, by, for example, submixing four kit mikes into a stereo pair so that I free up Firepod inputs. (Another advantage of th external mixer is the mute buttons on the tracks . . . something they need to do with interfaces, but which I have yet to see).
