N
NYMorningstar
Recording Modus Operandi
Do you compress individual channels, the sub channels and/or the main mix for say a common 5 piece rock band(guitars, keys, bass, drums, vocals)? Why?
Are your inserts pre or post aux sends? In other words, if you compress a vocal channel will the stage monitor get the compression?Every channel I have an inserted Comp/Limit/Gate sometimes they get used for the obvious reasons other times they get by passed.
You can put a comp on the sub group of say drums but as for on the main mix I have never been a big fan of for just one little peak can bring your whole mix down ... it can be run as a limiter if someone other than you is at FOH as a precaution.
Do you use compression on the channels for vocals? If so how do ou deal with the stage monitors?pre .
