R
rockabilly1955
Can somebody explain the difference between the two?? for example, I've used the W1 limiter plugin (supposed to be a L2 clone??) and it does a very comparable job in getting a songs apparent loudness up to that of a song that has been totally squashed with compression. The difference i see is that with the limiter, the the mix retains its dynamic range and all the peaks and valleys in the waveform, though numbers wise, its still lower than a squashed song, but sounds just as loud. Anybody have any advice in using these two?? which is better for final mixes?? should they be used together?? and why is that with the limiter the lower you set the threshold the louder it sounds?? yup....i'm still a newbie
