Chris Tondreau
Member
Hey there;
Yeah... I've been away for a bit, but it's nice to be back!!
A friend of mine bounced this off me to try, and though I was skeptical, I gave it a go - and it worked!!
He suggested this.... Plug a mic into a compressor (in my case, I plugged an SM58 into my Behringer Composer Pro compressor), bypassing most of the compressor controls, and crank up the make-up gain. Voila.... hot enough signal to record a mic - even without a mic pre anywhere in the chain. (in my case, compressor directly to the inputs of the Delta44). This seems to defy logic, in that a mic pre's purpose is to boost a "mic level" signal to "line level" in order that it may be "heard" by the recording device. Does the make-up gain REALLY boost it that much on it's own, or am I missing something more simple here?
BTW - I only checked for the meters to respond in the Delta44, and sound coming from my speakers. I didn't actually record anything to hear what it sounds like. It sounded okay through the speakers, though, and the meters read up about 3/4 of the way up the green, but not into the yellow, without really hitting the mic that hard.
Any thoughts on this?
Chris
He suggested this.... Plug a mic into a compressor (in my case, I plugged an SM58 into my Behringer Composer Pro compressor), bypassing most of the compressor controls, and crank up the make-up gain. Voila.... hot enough signal to record a mic - even without a mic pre anywhere in the chain. (in my case, compressor directly to the inputs of the Delta44). This seems to defy logic, in that a mic pre's purpose is to boost a "mic level" signal to "line level" in order that it may be "heard" by the recording device. Does the make-up gain REALLY boost it that much on it's own, or am I missing something more simple here? BTW - I only checked for the meters to respond in the Delta44, and sound coming from my speakers. I didn't actually record anything to hear what it sounds like. It sounded okay through the speakers, though, and the meters read up about 3/4 of the way up the green, but not into the yellow, without really hitting the mic that hard.
Chris
