this belongs in Mixing/Mastering.....
but why not continue here and wait for it to be moved.
verytorpe said:
so compression reduces the dynamic range of a song... let's see...
i've recorded about a dozen songs, some rather metal, some rather electronica, some pretty loud parts, some pretty soft parts... not a dozen punk rock songs repeating the same strum from start to end.
then...
why do they sound so f***ing lineal when you listen to the entire playlist? it is as if the word "crescendo" were not in my dictonary.is this problem related to compression? they all have a final stage of multiband compression (masterx3, with very similar parameters from one song to another...hmm...) and some eq after it, but the compression ratio is not that much (sometimes about 2:5, sometimes about 1:8) and none of the instruments is specially overcompressed at the recording/mixing stage.should I manually pump up the gain of louder parts, or reduce the softer ones? should i automate the final compression plugin? adding another multiband plugin? any whatever?
maybe i should post it in another thread... dunno
and thanks to everyone for your feedback!
Your compression problems sound farmiliar, I think everyone who is trying to grasp the concept (including me) for the first time has many frustrating moments. Don't worry it will all make sense as long as you don't toss that MF into a brick wall or something.
You've used compression (and multiband compression) on all of your songs, most with the same settings, and you say your album is very level linear (or lineal?).
First, take off
all the compression (if possible) you've put on. Proceed through the mastering process. While comparing song levels (with your ewars of course, not meters), if a song in the playlist needs to be louder, only then would you bring some compression into the picture. If you need it to be 3db louder, set the threshold to just above the average level (RMS) of the song, and adjust ratio until you have a 3db reduction, then add the 3db back with output gain.
If you don't NEED compression, don't use it. If you have one peak that keeps you from turning up, digitally edit it out by zooming in close, selecting the peak, and reduce the level manually. I've done this "manual" compression for entire songs, takes a lot of patience, but keeps you from getting too compressed. Why compress the entire song when you can manually remove the few problem peaks? This is just something to think about.
To avoid compression I also "ride the envolopes". If you have multitrack software, try using the volume evelopes to create crescendos and climax moments of a song.
My main point is not to depend to much on compression right now, while your still trying to figure it out. Use you imagination and common sense to come up with solution for YOUR own unique problems. If compression sounds bad to you, don't use it.
By the way, your ratios of 2:5 and 1:8 don't make much sense to me.
Ratios are the following:
input gain : output gain
i.e. 2:1
For every 2 db's over the threshold, 1 db come out of the compressor.
hope this helps,
Later.
