J
Jack Real
Hi
When a song is completed, I usually compress and maximize the song to give it more volume. I either find a threshold that has no meat above and apply 75% compression or if there is a little meat above the threshold, I apply a more gentle compression like 40 or 50%. Yesterday, I changed that process to use successive compression. One compression pass consist of 50% compression for everything that is above 0.8 volt (max is 1 volt) and after, I remaximize to 1 volt. I redo the same process over and over until the volume is high enough. Yesterday, I redid the process 3 times to this means that what was between 0.8 and 1 volt on the original wave was compressed 3 times, what was between 0.72 volt and 0.8 volt was compressed 2 times and what was between 0.63 volt to 0.71 volt was compressed 1 time. I find that process easier because I just redo the compresson pass until the volume is right so I don't have to look for the right threshold or the right compression %. Are there advantages or disadvantages to use this technic ? How does it affect the dynamic or the proximity effect of the song ?
Thanks,
Jack Real
Thanks,
Jack Real
