VSpaceBoy
..loading
Hey all,
I havnt needed to post very much because of all the info I can search up from you folks. Lotta brains in here. I do need a little help with something though.
From what I have read I've gathered that I should record vocals straight from the preamp. Then out, through an outboard compressor, then back to the pc. Only problem is I don't have enough connectors on my audiophile 2496 to do this practically.
I tried just recoding into the pc and using several different software compressors <which would be my first choice>. But to get what I need by way of compression is squashes the sound. The only outboard I would have is my GNX2 for my guitar. I was thinking maybe I could strip down all the modeling and such and just steal the compression out of it.
The problems I potentially see are this.
1 - Is the GNX2 ok for vocals, I'm thinking that effects are effects and yes it is for guitar but I'm thinking thats mostly the marketing for the presets.
2 - the GNX2 has a digital out. Does that mean I could leave the pre amp connected to the line in on the card for recording, then a line out to the GNX2, then the digital back into the card?
3 - Is it possible to record the compression to the track so I don't have to leave the GNX2 running all the time like regular outboard gear?
Seems to me that the best<easiest> choice would be software compression. I tried out the Sonic one, Timeworks, and the VSi one in Cubase. Unless I'm using them wrong I think they all kill the tone.
Thanks in advance!!
Space
Thanks in advance!!
Space
