comping/alternate/sub tracks automatically??
  • Thread starter Thread starter Jason Chinchen
J
Jason Chinchen
Made of rubber...
In reason when I want to record a new line with an instrument it pops up a new sub track under the original just by pressing record again .....is there a way to set up sonar 8 to do this? or do I just have to clone tracks in a sub folder every time?
That's the 'Sound on Sound' option. Normally it's 'On' by default, but if yours is off:
Click on 'Transport' in the menu bar and scroll down to 'Record options...'
Make sure "Sound on Sound (blend)" is ticked and "Store Takes in a single track" is ticked.
I'm not in front of my Sonar machine so that was from memory, but it should be close...
Hope this helps!
Do you mean that they will all record in the same track space? I want it to open a new track, etc...Ill try your advice in a bit..
Thanks!
You have the option of having each take record in a new track as well...
Good luck!
hmmm, i clicked that box too but no go yet, Ill play around. thanks.
I use the layers within tracks to accomplish this. In track view mode, click the Show Layers button. Then each time you hit record, a new layer is added to that track as a separate clip. I used this to get repeated takes of a single instrument. I can then go back and cut and paste the clips to get a perfect take, deleting the unused pieces when done.
