Shana said:
If it makes any difference I'm 20 years old and orthodox-which I'm sure is quite evident.
Shana said:Oh I'd love that
Just tell me what address. You can email me at Chanale77@aol.com
Thanx so much
Sent you my address via email.
As for James comment on the music sounding like backround music, you definitely have a point-It almost sounds like I'm doing kareoke. Thing is, In these two last songs I used my keyboard more than ever. What happens is that I "mix" the keyboard tracks b4 i dump them into the br8. Only then do I record vocals. So I actually cant tweak each sound to "envelope" the vocals. I mean i can't say can't but it's just harder.
Now for Shailat here's the thing
What do you mean compression on the whole mix? Add compression to each track?
Since you are using a programed synth you wont need compression, unless you are playing the rhythm parts yourself (as opposed to the synth doing it for you).
Of course this does make life easier but an automated synth rhythm, tends to be rather static dynamicly so
there is a trade off here........
If you can balance the keyboard mix well, then compress the vocals if needed only.
This will help them sit in the mix better. Then if the mix needs it compress lightly. In your song that I heard it needed it. But then again your vocals were to loud.
The Eq suggestion was of course for the vocals alone. Dont process the whole mix with that cut and boost I wrote about.
Dont forget a bit of pedelay on your reverb for your vocals as well.
PS YOU'RE MAKING ME WORK HARDER!!![]()
