Channel 5/6 on 414
  • Thread starter Thread starter Schmoe
Schmoe
Need some help on this one. Was recording drums with effects. Sent the signal out through effects one send, to effects unit, then into channel 5/6. Adjusted the 5/6 for the right amount of effects I wanted to record wet with. However, when I increased the amount on 5/6, the levels on that certain track went through the roof, even if the faders were set at 1 or 0. Does that 5/6 channel override the faders on the affected track? Do I have lower the effects 1 send very low? But if I increase the out on 5/6, the wet signal will peg the recording levels for that track. The more I think about it, I think I answered my own question. I guess I have a hard time understanding why the out on 5/6 would override the faders, even if they are set at 0.
Enlightenment anyone???
thanks
I think you are supposed to turn 5-6 ALL THE WAY UP.
Then you use your "Effect 1" knob as a Dry/Wet knob. If it's too loud, turn down the Output of the Unit. If it's too distorted turn down the Input of the unit.
Does this helP?
