Changing tempo without shifting pitch in Audition 1.5...?
  • Thread starter Thread starter Change of POETS
Change of POETS
Change of POETS
Is it possible to do this?
If so, how? How can I control the tempo?
I have a track right now that I need to slow down to 97 bpm but I can't figure out the time stretch to get it right. Anyone know if this is even possible?
I have changed pitch without changing tempo, and pitch+tempo by going to Edit View/Effects/Stretch and then selecting the options. For pitch changing I calculated the % of frequency shift between the keys I was going from/to (in this case, turning G# into G); for the pitch+tempo I was bringing the recording of a 78RPM vinyl disc that I had had to record at 33 up to speed.
If you know the tempo of the original, and the target tempo, you should be able to figure the ratio and enter it.
I don't believe you can do this in Multitrack View, but then I haven't tried it.
