I forgot about that thread. My answer at the time was;
"I think there's a a couple of things here that are being taken as absolutes that aren't really. Saying that a preamp puts out line level is one. A preamp is a variable gain stage that we use to drive our signals approximately to +4 dBu (1.228V (RMS)) or -10 dBV (0.3162V (RMS)), but that's totally a function of how much of it's available gain we use and the signal level we start with. Secondly, input voltages don't always fall into "line level" or "instrument level" as absolutes.
The DMP3 can take a maximum input of +14.6dBU, which calculates to 12.38dBV, or 4.15V (RMS). So, it will have no trouble at all accepting the line level output of a previous preamp stage, which isn't even at line level or we wouldn't be discussing this.
The other consideration is input impedance. We usually talk about just high impedance and low impedance, but mid impedance should probably be in our lexicon. High impedance in this discussion would be around 1M - 3M ohm, typical for instrument inputs. Mid impedance might be around 10k - 20K ohm, typical for line inputs. Low impedance is usually in the 600 ohm range. I believe there is more to be gained by having a high impedance input for pickup based sources than there is to be lost by presenting a line level signal to a high impedance (instrument) input. Someone can correct me if I'm wrong, but I don't think this presents a problem."
Also, I'd like to address an error someone made in that thread.........
"I think the most confusion surrounding this issue is the misconception that the gain pot on a preamp boosts the output of the amplifier. The gain of an amplifier chip is static... The gain pot is nothing but a variable attenuator... By turning it up you're actually decreasing the attenuation at the input to the preamp. The net result is that the output of the amp increases, but the amplifier doesn't provide additional amplification, it's just passing along what it sees on the input".
That simply is not true for most mic preamp designs. The gain control usually varies the feedback, changing the gain of the preamp. This is true for the classic Jenson twin servo design, and most other feedback amplifier topologies. That's why things get hissy when you turn them all the way up, even with the input grounded.
