My friend,...
there is quite a bit to internal calibrations that would require a fair amount of expertise, specialized tools, etc., that I could explain in detail but would probably not do you any good. The tools themselves would require substantial investment. Since your friend gave you the 414, maybe he could help you test it out to your satisfaction, so that it eliminates the very sight chance that there's something in your procedures that is causing this problem. Beyond that, it could probably be fixed by posting it to TEAC in Montebello, CA, and for perhaps $100-$125 or so repair cost plus shipping get it back to working order. However, when a 414mkII often goes on eBay for $80 or thereabouts, repair may not be practical on something someone gave you. A free Portastudio that works is great. Less good if it doesn't work.
Probably the biggest hinderance to home calibration is that you'd need a standard alignment tape which is obsolete, hard to find, and if you could find it would cost over $100 alone. You would also need some sort of tone generator and a volt meter to verify input/output levels. Of course you'd need the service manual, which Tascam may sell for about $30.
I'm not trying deliberately to be discouraging, but I have these tools and have calibrated a few machines, and it could take an experienced tech such as myself many hours, if you want to be very exacting about getting things dialed right in, like I do. More experienced guys around here will know when I reiterate the notion that a 2-head deck is way more difficult, tedious and time consuming to calibrate than a 3-head deck. All Portastudios and most consumer cassette decks are 2-head recorders.
With that being said, I'll be one of a few people here that will vouch that the 414 is a very nice recorder setup that sounds excellent when it's working. Personally, I have a couple of them myself that need fixing, but that's probably another story.
I'm not trying to boost myself up or burst anyone's
bubble, but as far as Portastudio calibration goes, it's a deep subject and there's a lot to it.
Back to your issue, specifically, if you feel comfortable enough to burst this unit apart with a screwdriver, the least you could do is pull and reseat all connectors, just to verify it's not a dirty or tarnished internal connection. A mid level technical novice could probably do that. Calibration is another thing entirely, to do it right. A more experienced techy type could probably take a screwdriver and the service manual, and in a matter of a few internal tweaks get levels back up to usability, but without a standard alignment tape to start, it maybe functional but it wouldn't be aligned to any standard.
That is a long answer to a seemingly simple question, but under the surface that question is not simple at all.
