K
Kristoffel
Before I go any further, the brunt of my question is: "Am I really going to need to rip out the existing drywall ceiling?"
Hi, I recently bought a house and plan to turn one of the bedrooms -- 14' x 10' x 7'9" -- into a project studio for some recording of just me doing vocals, guitar and "lightweight" mixing. I live alone in a single-level ranch house in a suburban neighborhood, where principal noise sources are car noise, neighbors and -- this one is currently my concern -- airplanes that fly "somewhat" high overhead but still can be easily heard in the existing house. I feel okay with plans for isolating walls, windows and doors, but for the ceiling, I'm...confused as to what path to follow.
I have Grammy-winning mixing & mastering engineer friends who work out of suburban home studios tell me they've had great success, isolation-wise, by just adding to all walls & ceiling a couple more layers of drywall with green glue in between. No room-within-a-room construction, no ceiling mounts via resilient channels, etc. (also no putty around outlet boxes, no MLV sheets, etc). But their houses are also in different neighborhoods, perhaps not with airplanes overhead. ;-)
A semi-retired pro studio designer friend came and looked and recommended (free advice) ripping out the ceiling and putting QuietRock *above* the joists (i.e. up in the attic under the slanted roof), then stuffing in 4" rockwool below that, then a 1" air gap, and then 2" rockwool, and cover the underside with cheesecloth or somesuch. This would address both the isolation (for the ceiling) and also provide some broadband absorption and might even help a bit with the 0,0,1 axial mode around 70 Hz. I'm sure it would sound great, except that...
*Nobody* else I've been talking to will affirm doing this work, either from a pure-construction standpoint ("that's going to be a total bitch to do, ripping out the ceiling seems drastic") or a home-resale standpoint ("nobody is going to want that in their new home if you were to try to sell the place...although you could just drywall over it if it came to that.").
Ok, so instead I could take the path of installing resilient dampening channels and do DD+GG as my buddies did, but it seems like if I were to do that, I'd have to rip out the drywall ceiling anyway to get at the joists. And I'd be lowering the ceiling even more in doing that. And it wouldn't give me any absorption that my friend's plan had. ...I could hit that 0,0,1 mode by putting in diaphragmatic absorbers elsewhere though.
Can I get any other informed opinions on this?
Thanks.
Thanks.
