E
Emeric
I can try and answer a few questions:
1. External drives are more expensive and are usually SCSI or USB. Is portability an issue? Internals can be SCSI or IDE, IDE is less expensive. SCSI has the advantage of allowing you to multitask while it's burning (something I never do regardless of which it is), use to be faster and more reliable, but these days IDE is plenty quick - and reliable.
Best brands: I've used Mitsumi's and Yamaha's. Both with good results. If your leaning towards SCSI, Yamaha would be my pick. There are a few other brands no doubt someone else will mention.
2. Yes, you need a 1/8" stereo male to 2 RCA males. For video you need some type of video capture card, ATI "all in wonder" comes to mind, but there are others, both more expensive and less.
3. Check out the products by Sonic Foundry. I don't know anything about DJ stuff or video editing - someone on this BBS is into the video editing, can't remember name.
Another thing you may want to consider is what sound card you will be using. What are your requirements, high end, middle of the road, low end? Range in price from $30 $1000+
Hope this helps.
Hope this helps.
