Kingofpain678
Returned from the dead
Aluminum has some strange properties, and it’s the only commercially available metal I know of that can eliminate the buzz caused by light dimmers. An inch thick copper or brass shield cannot reduce the buzz caused by light dimmers but .003 thick aluminum foil can! This is known some thirty years and the reason why Belden introduced double shielded cable ( Copper braid plus aluminum foil). There is one problem for guitar cords -- the double shielding makes the cable too stiff . It helps quite a bit when you shield your guitar with copper and aluminum foil.
Try this one-- wire a single coil to a jack and plug it into your amp. Put the pickup on a table next to your amp. Take an aluminum pan from your kitchen and put it slowly on top of your single coil and watch the hum disappear.
- Bill Lawrence
I've done some research and found that it's okay to use aluminum foil as an alternative to copper foil to shield the electronics cavity in a guitar... From what I understand, You just keep connectivity from the ground to the shielding which shouldn't be any problem I wouldn't think.
Only problem is, I read that shielding a guitar's cavities kill the liveliness of a pickup. I'm not sure how that statement could hold any water but I figured it wouldn't hurt to ask...
So, is there any way shielding can effect the sound of a pickup?
